Текущее время: 12 июл 2025, 16:51
Cassini
 COWON S9 Firmware 2.50
Обновления/Изменения:
- Changed Main menu GUI.
- Improved sensitivity of button touch.
- Support multi-subtitles in video mode (up to 2)
- Support continuous playback of files on the list without stopping in TV out mode.
- Fixed the error that certain WMV files were not played properly.
- Added function that return to work with COWON S9 after hanging up cell phone when your Bluetooth device is multi-paired with COWON S9 and cell phone.
- Fixed the paring error of Bluetooth with certain digital TV which supports Bluetooth.
- Fixed the error that certain WMA tags were not displayed.
- Fixed the error that certain M3U format was not recognized.
[b]Обновления/Изменения:[/b] [b] [list] [*]Changed Main menu GUI. [*]Improved sensitivity of button touch. [*]Support multi-subtitles in video mode (up to 2) [*]Support continuous playback of files on the list without stopping in TV out mode. [*]Fixed the error that certain WMV files were not played properly. [*]Added function that return to work with COWON S9 after hanging up cell phone when your Bluetooth device is multi-paired with COWON S9 and cell phone. [*]Fixed the paring error of Bluetooth with certain digital TV which supports Bluetooth. [*]Fixed the error that certain WMA tags were not displayed. [*]Fixed the error that certain M3U format was not recognized.[/list][/b]
[b][center][url=http://www.cowonglobal.com/download/Firmware/COWONS9/COWON_S9_2.50.zip]Скачать[/url][/center][/b]
03 ноя 2009, 16:28 |
bill_v2
 Re: COWON S9 Firmware 2.50
УРРА! в 2.50 пофигсен баг с SRT-субтитрами, когда каждая вторая буква в кодировке 1251 пропадала! дошел-таки мой багрепорт!  а еще это сообщение №4444 в теме про S9
УРРА! в 2.50 пофигсен баг с SRT-субтитрами, когда каждая вторая буква в кодировке 1251 пропадала! дошел-таки мой багрепорт! :Yahoo!: [offtopic]а еще это сообщение №4444 в теме про S9[/offtopic]
14 дек 2009, 03:01 |
Nekroskop
Зарегистрирован: 22 май 2009, 19:10 Сообщения: 229 Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon S9, FW 2.51 Наушники: Fischer Audio Sigma
Ого, крута))) даже не в теме был по поводу субтитров, по привычке перекодировал  Спс за инфу
Ого, крута))) даже не в теме был по поводу субтитров, по привычке перекодировал :D Спс за инфу :D
_________________ A Cornered Fox is More Dangerous Than a Jackal steam account
14 дек 2009, 09:40 |
Blood13
Зарегистрирован: 14 окт 2009, 13:42 Сообщения: 61 Откуда: Карелия Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon S9 16gb 2.52 Наушники: default
скорее бы пофиксили косяки из 2.5
14 дек 2009, 11:14 |
Leviathan
Зарегистрирован: 18 авг 2009, 04:09 Сообщения: 28 Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon S9 Firm 2.51 Наушники: AKG k-55
Ну это аналог виджетов. Я считаю вполне удобным этот экран. Им и пользуюсь. Работает не намного медленнее, а ярлыки расположить все довольно удобно. Я думаю, "на вкус и цвет" здесь как говорится...
14 дек 2009, 15:51 |
Greetings_a_brain
Зарегистрирован: 13 ноя 2009, 17:34 Сообщения: 24 Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon s9 Наушники: Fischer Audio Sampi
Мм,если сравнить аэро ультимейт джи два и собственный ковоновский трехэкранный рабочие столы,то стол аэро (который ,как я выяснил из собственного опыта, более функционален) работает шустрее ковоновского,тогда зачем тебе ковоновский ,если можно поставить аэровский?=)))
_________________ [Cowon s9 2.50][Fischer Audio Sampi] И кожанный чехольчик в подарок.=)
15 дек 2009, 19:53 |
Cassini
Greetings_a_brain писал(а): Мм,если сравнить аэро ультимейт джи два и собственный ковоновский трехэкранный рабочие столы,то стол аэро (который ,как я выяснил из собственного опыта, более функционален) работает шустрее ковоновского,тогда зачем тебе ковоновский ,если можно поставить аэровский?=))) Неверно, аеровский экран не быстрее, можно это даже проверить опытым путём встраивания датчика FPS. И сажает батарею он сильнее, в ковон над этим задумываются в первую очередь, остальные разработчики о батареи и быстродейтствии не думают, либо думают, когда уже всё сделано )))
[quote="Greetings_a_brain"]Мм,если сравнить аэро ультимейт джи два и собственный ковоновский трехэкранный рабочие столы,то стол аэро (который ,как я выяснил из собственного опыта, более функционален) работает шустрее ковоновского,тогда зачем тебе ковоновский ,если можно поставить аэровский?=)))[/quote] Неверно, аеровский экран не быстрее, можно это даже проверить опытым путём встраивания датчика FPS. И сажает батарею он сильнее, в ковон над этим задумываются в первую очередь, остальные разработчики о батареи и быстродейтствии не думают, либо думают, когда уже всё сделано )))
16 дек 2009, 19:13 |
gravesnake
Зарегистрирован: 02 дек 2009, 22:03 Сообщения: 2 Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon S9 Наушники: Fischer Eterna
Хотел спросить . Если слушать радио , потом посмотреть видео и сново включить радио , то звук становится тише . Это только у меня так или у всех ?
16 дек 2009, 21:52 |
VaniaLSD1
Зарегистрирован: 25 май 2009, 21:53 Сообщения: 21 Благодарил(а): раз. Поблагодарили: раз. Плеер: S9 32gb
Стоит ли прошиваться на 2,50 или лучше на 2,41?
17 дек 2009, 15:38 |
anman
Зарегистрирован: 09 апр 2009, 00:31 Сообщения: 203 Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon S9, FW 2.51
VaniaLSD1 Если тебе важно, чтобы плеер выключался через пару минут когда ставишь на паузу, то оставайся на 2.41.
[b]VaniaLSD1[/b] Если тебе важно, чтобы плеер выключался через пару минут когда ставишь на паузу, то оставайся на 2.41.
_________________ Cowon S9 16Gb Titanium + Sony MDR-EX85LP + Sennheiser HD 212Pro. Claw's Wallpaper UI v3.49 HTC Desire. ******************************* (наведите курсор чтобы увидеть секретную фразу)
17 дек 2009, 16:17 |
Oper.kh
Зарегистрирован: 17 сен 2009, 21:16 Сообщения: 44 Откуда: Украина, Харьков Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon S9 16 GB, 2.41 Наушники: Grado SR-60
Если из нововведений и исправлений ничего не привлекает, лучше на 2.41 остаться.
З.Ы. Уже 2 человека, у которых стоит 2.50 советуют оставаться на 2.41 и при этом сидят на 2.50 =)) Видимо лень откатываться)
_________________ Cowon S9 16GB Titanium Black, 2.41(откатился) + Grado SR-60
17 дек 2009, 21:53 |
El_Zero
Oper.kh писал(а): Уже 2 человека, у которых стоит 2.50 советуют оставаться на 2.41 и при этом сидят на 2.50 =)) Видимо лень откатываться) Успользуй ту прошивку, что удобнее тебе. После 2,50 плеер стал нормально воспринимать m3u плейлисты, мне например это по нраву, а на тормозящее меню плевать.
[quote="Oper.kh"]Уже 2 человека, у которых стоит 2.50 советуют оставаться на 2.41 и при этом сидят на 2.50 =)) Видимо лень откатываться)[/quote] Успользуй ту прошивку, что удобнее тебе. После 2,50 плеер стал нормально воспринимать m3u плейлисты, мне например это по нраву, а на тормозящее меню плевать.
17 дек 2009, 22:36 |
anman
Oper.kh Да. Мне лень откатываться и опять настраивать wallpaper ui
[b]Oper.kh[/b] Да. Мне лень откатываться и опять настраивать wallpaper ui
18 дек 2009, 00:06 |
VaniaLSD1
Ну вот есть не довольные: gravesnake писал(а): Хотел спросить . Если слушать радио , потом посмотреть видео и сново включить радио , то звук становится тише . Это только у меня так или у всех ? У меня стоит 2.30
Ну вот есть не довольные: [quote="gravesnake"]Хотел спросить . Если слушать радио , потом посмотреть видео и сново включить радио , то звук становится тише . Это только у меня так или у всех ?[/quote] У меня стоит 2.30
18 дек 2009, 17:17 |
crwin
Зарегистрирован: 11 авг 2009, 19:03 Сообщения: 54 Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon S9 Наушники: Audio-Technica ES7
Цитата: Мне лень откатываться и опять настраивать wallpaper ui а что там настраивать то? папку с настройками перенести да и всё. да и то, после "перепрошивки" они не денутся никуда
[quote]Мне лень откатываться и опять настраивать wallpaper ui[/quote] а что там настраивать то? папку с настройками перенести да и всё. да и то, после "перепрошивки" они не денутся никуда
_________________ Wallpapper UI / J3 Theme noise/electro music fan
18 дек 2009, 21:35 |
anman
crwinТак ведь хочется сразу версию посвежее поставить. А уж тогда точно настраивать придется. Леееееееень. Хотя, тут скоро сессия, вот тогда сразу столько дел появится. И плеер прошить, и винду переустановить, чтобы меньше тормозило при подготовке к экзаменам, потом, напр., давно хотел фильм посмотреть - надо и фильм посмотреть.Цитата: 394121 [ 2527 ] смешно / [:||||:] / не смешно / утверждена 2008-01-08 в 12:42 Melhesedek: если в сессию запереться в комнате с кроватью, едой, гитарой и учебниками, то к началу семестра можно стать выспавшимся жирным хорошим музыкантом..
[b]crwin[/b] Так ведь хочется сразу версию посвежее поставить. А уж тогда точно настраивать придется. Леееееееень.
[color=#808080]Хотя, тут скоро сессия, вот тогда сразу столько дел появится. И плеер прошить, и винду переустановить, чтобы меньше тормозило при подготовке к экзаменам, потом, напр., давно хотел фильм посмотреть - надо и фильм посмотреть.[/color][quote][color=#808080]394121 [ 2527 ] смешно / [:||||:] / не смешно / утверждена 2008-01-08 в 12:42 Melhesedek: если в сессию запереться в комнате с кроватью, едой, гитарой и учебниками, то к началу семестра можно стать выспавшимся жирным хорошим музыкантом..[/color][/quote]
19 дек 2009, 00:16 |
