Текущее время: 18 сен 2025, 06:16
История изменений и выхода прошивок [Firmware Change Logs]
Плеер: Cowon S9, FW 2.51
История версий: дата выхода, сделанные изменения, ссылка на скачивание и, если существует, ссылка на руководство по новым функциям для каждой прошивки.
COWON S9 Firmware V2.53 (02.08.2010)
  • Improved overall speed of UI.
  • Fixed the playback error of some MP3 and OGG files.
  • Fixed the error that some images are not displayed correctly.
  • Fixed the error of gapless playback in mono audio files.
  • Fixed the error that sound was muted when flash contents were played repetitively.
  • Fixed the error of subtitles of some video files.
  • Fixed the error that clock was stopped in certain circumstance in Main Manu 3.
Download COWON S9 Firmware V2.53
New features guide
COWON S9 Firmware V2.52 (03.03.2010)
  • Improved album art quality.
  • Fixed the error that objects were not moving when controlled to maneuver suddenly in a large motion.
  • Fixed the error of playback OGG files that contain ID3 tags.
  • Fixed the error that duration was not displayed while playing some OGG files.
  • Fixed the error that playback of some OGG files stopped by pressing FF button or touch fast forward on the screen
Download COWON S9 Firmware V2.52
COWON S9 Firmware V2.51 (21.01.2010)
  • MainMenu1 - Moved location of the power button.
  • MainMenu2 - Added power and music playback buttons.
  • MainMenu3 - Improved speed.
  • Fixed the error that auto turn off is not working properly in some situation.
  • Fixed some errors at hold status in Videos mode.
  • Fixed the display error of some subtitles in Videos mode.
  • Fixed the error in music playback with some files that contain irregular album art.
  • Fixed the error in music playback with some FLAC files that contain irregular tags.
  • Fixed the error that some widget setting was not saved correctly after turning off system.
Download COWON S9 Firmware V2.51
New features guide
COWON S9 Firmware V2.50 (03.11.2009)
  • Changed Main menu GUI.
  • Improved sensitivity of button touch.
  • Support multi-subtitles in video mode (up to 2)
  • Support continuous playback of files on the list without stopping in TV out mode.
  • Fixed the error that certain WMV files were not played properly.
  • Added function that return to work with COWON S9 after hanging up cell phone when your Bluetooth device is multi-paired with COWON S9 and cell phone.
  • Fixed the paring error of Bluetooth with certain digital TV which supports Bluetooth.
  • Fixed the error that certain WMA tags were not displayed.
  • Fixed the error that certain M3U format was not recognized.
Download COWON S9 Firmware V2.50
New features guide
COWON S9 Firmware V2.41 (17.08.2009)
  • JetEffect 3.0
    * Added Reverb sound effects: Reverb effect gives you feeling of real circumstance.
    * Added 9 presets: total 39 presets.
    • Maestro
    • Feel the Wind
    • Mild Shore
    • Crystal Clear
    • Reverb Room
    • Reverb Club
    • Reverb Stage
    • Reverb Hall
    • Reverb Stadium
    * It is possible to apply EQ filter, BBE, Stereo Enhance, and Reverb at the same time.
  • Improved touch sensitivity
  • Improved MP3 gapless playback.
  • Fixed the error of gapless playback in some OGG files.
  • Improved playback of OGG files.
  • Fixed the error of tags in some FLAC files.
  • Fixed the displaying error in some video files.
  • Support video files that contains PCM audio codec.
Download COWON S9 Firmware V2.41
New features guide
COWON S9 Firmware V2.31 Beta2 (24.07.2009)
  • Support gapless playback in MP3 files.
  • Improved DivX3 playback performance and hours of continuous playback.
  • Fixed the error that audio synchronization was not working properly when some AVI 2.0 files are searched in 0 second.
  • Fixed the error that some files display frame rate incorrectly.
  • Fixed the error that audio plays faster than video in some video files.
  • Fixed date created of DMB, DAB, and recording files.
Gapless playback in MP3 files:
  1. MP3 Gapless playback is the uninterrupted playback of consecutive audio tracks without intervening silence sections in front and end of files that are created while compressing mp3 files.
  2. COWON S9 supports gapless playback in MP3 files that are converted by LAME MP3 encoder such as type of plugins.
  3. Gapless playback won't be supported, if original audio file contains silence part in front and end before converting MP3 files.
Download COWON S9 Firmware V2.31 Beta2
New features guide
COWON S9 Firmware V2.31 Beta (29.06.2009)
  • Added the typist feature that is a notepad with a keyboard.
  • Improved receiving quality, compatibility, and performance of Bluetooth.
  • Support gapless playback in lossless music files (WAV, FLAC, APE, and LOSSLESS WMA) and OGG files.
  • Support M3U.
  • Support AVI files that are damaged.
  • Fixed the error that frame color wasn’t changed in document mode.
  • Fixed some minus operation error in calculator.
  • Support Thai.
Support M3U:
  • Functionality that recognizes M3U files that are created in PC.
  • M3U folder will be created in 'playlist' from the top menu of browser when you copy .m3u files in COWON S9.
  • COWON S9 recognizes up to 400 M3U files.
  • COWON S9 recognizes up to 400 lists in M3U.
  • ONLY support extended M3U.
New features guide
COWON S9 Firmware V2.30 (22.05.2009)
  • Added to display the title of the music file on the screen when you start music in matrix browser.
  • Improved displaying picture quality of album art in Music mode.
  • Improved conducting speed when you play music.
  • Added settings that you can choose sharpen or soften tone in Video mode.
  • Fixed the error that resume functionality were occasionally not working.
  • Fixed errors in UCI FSCommand 'EtcUsrSetString', 'EtcUsrGetString'.
Download COWON S9 Firmware V2.30
New features guide
COWON S9 Firmware V2.30 Beta (28.04.2009)
New features:
  • Added matrix browsing feature that you can browse music files by album art to rotate COWON S9 sideways.
    * Added a feature that playback music by album.
    * It is recommended to save album art by COWON MediaCenter.
    * It might take a while to load a high resolution album image, if it doesn’t have thumbnails.
  • Added Swing motion feature that skip to next or previous music in portrait mode.
    * It is possible to skip files by swinging your COWON S9 to the left or right.
    * Selection of Off, Swing motion, or Matrix browsing
  • Added a feature that you can set a picture that draw by notepad as wallpaper.
    * It is possible to set a picture, which you draw in notepad, as wallpaper.
  • Added 'Hunter' that is a G-sensor game.
Improvements:
  • Improved feedback speed when music or video files are paused.
  • Fixed the error that music tags are overlapped when ID3 tags contain NULL text in genre.
    * applied from newer files.
Download COWON S9 Firmware V2.30 Beta
New features guide
COWON S9 Firmware V2.20 (15.04.2009)
New features:
  • Added Notepad. (It is difficult to write small texts because the touch screen is capacitive-type.)
  • Added multi screens in Widget.
  • Added a transparent clock in Widget.
Improvements:
  • Fixed the error that APE and some music files are not working properly.
  • Improved playback performance of some high-resolution video files.
  • Improved playback performance of some video files that has faulty frame.
Download COWON S9 Firmware V2.20
New features guide
COWON S9 Firmware V2.10 (01.04.2009)
New features:
  • Added a feature of subtitle synchronization in Movie mode.
  • Added GUI buttons in Movie mode (subtitle synchronization, playback speed control, and JetEffect).
  • Support DivX3 codec in Movie mode.
  • Added to slide album art images when you tap screen toward right or left, even if the files don’t have album art in vertical Music mode.
  • Added pitch correction for playback speed control in Music mode.
  • Support Audible.
Improvements:
  • Improved battery life when high resolution (over 480*272) files are played in Movie mode.
  • Continuous Playback hour is depends on files but it is improved up to 75%. (ex> 6hours -> 10 hours 30 minutes)
  • Improved Widget GUI.
  • Fixed the error that some image color was discolored in Picture mode.
  • Fixed an exit button in calculator.
Download COWON S9 Firmware V2.10
New features guide
COWON S9 Firmware V2.10 Beta (11.03.2009)
Added function:
  • Added Widget. *
  • Support WMV7, WMV8 codec and ASF file.
  • Added pitch correction function when adjust playback speed of video files.
  • Added full screen mode in TV-out mode. **
  • Support Unicode (UTF-8) and color tags for subtitles. ***
  • Added a function to pick wallpaper pictures in picture mode. ****
  • Added function of hiding controller in picture viewer.
  • Added option of entering passkey(PIN code) to connect Bluetooth. *****
Improved function:
  • Improved function of playback next or previous songs by dragging right or left screen in Music mode.
  • Improved Brower scrolling.
  • Fixed to delete music files only in music folder.
  • Improved method of recognizing ID3 Tags in Music library mode.
  • Improved to play some of irregular MP3 files that didn’t play properly.
  • Fixed the error that some lyrics, which made by LDB 2.0, were stopped working.
  • Improved to support some movie files that were not supported.
  • Fixed the error that document viewer skips a line in text irregularly.
* What is widget? Widget is short term of Wise Gadget that gathering of useful toolbars.
** Full screen in TV-OUT mode: it is able to select display mode by press “-” button.
*** Support subtitles by form of code and colors of tags.
**** Set wallpaper image: picture mode > Select picture and enter viewer > Zoom or move to adjust images that you wish to put on the wallpaper > press wallpaper button.
***** Added option of entering PIN code to support Bluetooth headset which pin code is not 0000.
Download COWON S9 Firmware V2.10 Beta
New features guide
COWON S9 firmware V2.09 (09.02.2009)
Improved Feature & Fixed Bugs:
  • Fixed the error that movies are not playing properly when repeating section A was 00:00:00 in videos mode.
  • Improved recognition time of G-sensor in videos mode.
  • Improved stability of playback OGG files.
Download COWON S9 firmware V2.09
COWON S9 firmware V2.08 (29.01.2009)
  • Improved the process of page-up and down in documents mode.
  • Display charging status when the device is connected to PC by USB cable.
  • Improved low bit rate MP3 playback.
  • Fixed the error that auto pivot was irregularly not working when auto pivot is just changed to be on.
  • Fixed the error that displaying files abnormally when music in music favorites is playing in shuffle mode.
  • Fixed the error that Bluetooth headset was not working when turn on Bluetooth while some particular music
    files are playing.
Download COWON S9 firmware V2.08
COWON S9 firmware V2.07 (09.01.2009)
  • Added turn on/off auto pivot feature in music mode.
  • Added power saving feature when a movie is paused.
  • Adjusted size of subtitles while using TV-out in video mode.
  • Fixed the error that some subtitle files are irregularly not working properly in video mode.
  • Fixed the error that a line is overlapped with previous page in documents mode.
Download COWON S9 firmware V2.07
COWON S9 firmware V2.06 (24.12.2008)
  • Added to display album arts by changing image file name to .jpg.
  • Support Bluetooth speakers.
  • Fixed to not appear ‘Invalid Resource’, which was appeared rarely, when reboot the device after safely
    remove hardware from PC.
Download COWON S9 firmware V2.06
COWON S9 firmware V2.05 (19.12.2008)
  • Fixed the error that pivot was not firmed when play next file even though auto pivot option is off.
  • Fixed the error in GUI when memory gets full while recording radio.
  • Fixed the error in GUI when the device is connected to Bluetooth headsets for mobile phones.
Download COWON S9 firmware V2.05
HTC Desire.
Последний раз редактировалось anman 02 авг 2010, 15:10, всего редактировалось 3 раз(а).
09 ноя 2009, 12:33
 История изменений и выхода прошивок [Firmware History Logs]
История версий: даты выхода, обновления, исправления на Русском языке.
COWON S9 Firmware V2.05 (19.12.2008)
Исправления и обновления:
  • Исправлена функция автоповорота в режиме музыки.
  • Исправлена ошибка в интерфейсе, когда свободная память заполнялась, при записи радио.
  • Исправлена ошибка в интерфейсе, когда плеер присоеденён к Bluetooth гарнитуре для мобильного телефона.
Загрузить COWON S9 Firmware V2.05
  • Добавленна поддержка портативных Bluetooth колонок.
  • Исправлена ошибка отображения ‘Invalid Resource’ при старте плеера , которая иногда появлялась после безопасного
    отключения плеера от ПК
Загрузить COWON S9 Firmware V2.06
  • Добавлена опция включения/отключения G-Sensor в режиме проигрывания музыки.
  • Добавлен режим сохранения заряда аккумулятора в режиме видео, если воспроизведение видео приостановлено.
  • Скоректирован размер субтитров при использовании ТВ-Выхода в режиме воспроизведения видео.
  • Исправлена ошибка, когда некоторые файлы субтитров не работали должным образом в режиме видео.
Загрузить COWON S9 Firmware V2.07
  • Улучшено пролистывание страниц в режиме просмотра документов.
  • Реализовано отображение процесса зарядки аккумулятора при соединении по USB.
  • Улучшено качество воспроизведения низкобитрэйтных MP3-файлов.
  • Исправлена некорректная работа G-Sensor'a.
  • Исправлена ошибка отображения файлов, когда музыка из Избранного воспроизводится в случайном (Shuffle) режиме.
  • Исправлена ошибка включения Bluetooth при воспроизведении аудио-файлов.
Загрузить COWON S9 Firmware V2.08
  • Исправлено отображение видео при установленной в 00:00:00 повторяющейся секции А.
  • Улучшено время распознавания G-сенсора в видео режиме.
  • Повышена стабильность воспроизведения OGG-файлов.
Загрузить COWON S9 Firmware V2.09
  • Добавлена поддержка виджетов.
  • Добавлена поддержка WMV7, WMV8, ASF кодеков.
  • Добавлена возможность менять скорость воспроизведения видео
  • Добавлен полноэкранный режим для ТВ-Выхода.
  • Добавлена возможность смены фона
  • Добавлена опция автоскрытия панелей при просмотре фотографий
  • Добавлена опция ввода пароля для соеденения по блютуз.
  • Исправлен скроллинг в браузере.
  • Исправлена ошибка удаления музыки.
  • Улучшен метод распознования ID3 тегов в музыкальной библиотеки.
  • Исправлена ошибка некорректного воспроизведения некоторых мп3 файлов.
  • Исправлена ошибка, когда некоторые тексты песен (лирика), сделанные при помощи LDB 2.0 не работали.
  • Исправлена поддержка некоторых видео файлов, которые раньше не воспроизводились должным образом.
  • Исправлен ошибка в просмоторщике текста, когда при пролистывании пропуслкается одна строка текста.
Загрузить COWON S9 Firmware V2.10 Beta
Демонстрация новых возможностей
  • Добавлена функция синхронизации субтитров в режиме воспроизведения видео.
  • Добавлены новые кнопки в видео интерфейсе (Синхронизация субтитров, Скорость воспроизведения, JetEffect).
  • Добавлена поддержка DivX3 кодека в режиме воспроизведерия видео.
  • Добавлен эффект слайда для CoverArt.
  • Добавлена тональная коррекция в режиме воспроизведения мызику.
  • Добавлена поддержка аудио книг в формате Audible.
  • Увеличено время продолжительности воспроизведения видео в разрешении больше чем 272х480.
  • Исправления в интерфейсе виджетов.
  • Исправлено неверное отображение цеветовой палитры в режиме просмотра фотографий.
  • Исправлена кнопка выхода в приложении Калькулятор.
  • Добавлено приложение Notepad.
  • Добавлено несколько рабочих столов в интерфейс виджетов.
  • Добавлены прозрачные часы в интерфейс виджетов
  • Исправлена ошика, когда некоторые APE и другие музыкальные файлы не воспроизводились корректно.
  • Улучшена производительность при воспроизведении видео высокого разрешения, выше чем 272х480.
  • Улучшена производительность при воспроизведении видео, когда видео файл имел битые кадры.
Загрузить COWON S9 Firmware V2.20
  • Добавлен матричный браузер CoverArt в режим воспроизведения музыки.
  • Добавлена возможность воспроизведения копмозиций по альбомам.
  • Добавлена возможность установить в качестве фона рисунок нарисованный в приложении Notepad.
  • Добавлена игра'Hunter'.
  • Улучшенна скорость обратной связи, когда воспроизведение музыки или видео файлов приостановлена.
Загрузить COWON S9 Firmware V2.30 Beta
  • Повышено качество картинки с заставкой альбома в режиме Music.
  • Улучшено ведение скорости при аудио воспроизведении.
  • Добавлены функции повышения/понижения резкости в режиме Video.
  • Исправлена ошибка, из-за которой иногда не работала функция Resume (возобновление воспроизведения).
  • Исправлены ошибки в интерфейсе, FSCommand 'EtcUsrSetString', 'EtcUsrGetString'.
  • Добавлено приложение Notepad с клавиатурой.
  • Улучшено качество приёма Bluetooth.
  • Добавлена поддержка gapless воспроизведения для музыкальных файлов WAV, FLAC, APE, LOSSLESS WMA, OGG.
  • Добавлена поддержка плейлистов в формате M3U.
  • Исправлена ошибка смены фона в режиме просмотра документов, в некоторых случаях он не менялся.
Загрузить COWON S9 Firmware Beta
  • Добавлена поддержка gapless воспроизведения для музыкальных файлов в формате MP3.
  • Улучшено быстродействие, при воспроизведении видео в формате DivX3.
  • Исправлена ошибка аудиосинхронизации в режиме воспроизведение видео.
  • Исправлена ошибка, когда аудио дорожка опережала видео в некоторых видео файлах.
Загрузить COWON S9 Firmware V2.31 Beta2
  • Добавлена новая версия JetEffect 3.0
  • Добавлен новый звуковой эффект, Ревербрация.
  • Добавлено 9 новых предустановок эквалайзера.
  • Улучшена чувствительность сенсорного экрана.
  • Улучшено gapless воспроизведение.
  • Исправлено воспроизведение gapless в некоторых OGG файлах.
  • Исправлены ошибки отображения тегов в некоторых FLAC файлах
  • Добавлена поддержка видео файлов в контейнере PCM Audio Codec.
Загрузить COWON S9 Firmware V2.41
  • Изменён интерфейс главного меню.
  • Улучшена чувствительность сенсороного экрана.
  • Добавлена поддержка мульти-субититров.
  • Добавлена поддержка продолжения воспроизведения видео в режмие Тв-Выхода, при просмотре списка файлов.
  • Исправлена ошибка при которой некоторые WMV файлы не воспроизводились должным образом.
  • Исправлена ошибка, когда определенные теги WMA не отображались.
Загрузить COWON S9 Firmware V2.50
COWON S9 Firmware V2.51 (03.11.2009)
    Усовершенствован интерфейс главного меню.
    Исправлена функция автоотключения питания, не работавшая в некоторых ситуациях.
    Исправлены ошибки, возникавшие при просмотре видео в режиме блокировки (Hold).
    Исправлена ошибка отображения некоторых субтитров.
    Исправлена ошибка аудио режима, возникавшая при использовании нестандартных изображений обложек альбомов.
    Исправлена ошибка обработки FLAC-файлов, содержащих нестандартные тэги.
    Исправлена ошибка принятия некоторых из сохранённых ранее установок плеера после его перезапуска.
http://www.cowonrussia.ru/index.php?action=drivers&mode=search&driver_id=112
COWON S9 Firmware V2.52 (03.11.2009)
    Улучшено отображение обложек альбомов.
    Исправлена ошибка проигрывания ogg файлов, содержащих ID3 теги.
    Исправлена ошибка, при которой не отображалась продолжительность проигрывания некоторых ogg файлов.
    Исправлена ошибка, при которой попытка перемотки вперёд приводила к остановке воспроизведения некоторых ogg файлов.
    http://www.cowonglobal.com/download/Firmware/COWONS9/COWON_S9_2.52.zip
09 ноя 2009, 15:13
Сообщение Re: История изменений и выхода прошивок [Firmware Change Logs]
Неплохо бы обновить в связи с выходом 2.51, и порядок сделать наоборот, вначале старшие, а потом уже младшие прошивки - не придется прокручивать в конец сообщения. Новое всегда сверху.
22 янв 2010, 15:00
Плеер: S9, FW 2.52
Наушники: PHILIPS SHP1900
2.52...
Shut the f**k up, Donnie!!!
Rock-n-roll
кто - я, тот умный молодец
04 мар 2010, 14:53
Ulve
Обновим, после выхода официальной русской версии.
04 мар 2010, 15:26
Плеер: Cowon S9, FW 2.52
Наушники: Sennheiser CX200
На оффсайте написано 2.51
Плеер белым по чёрному пишет - 2.52
Ошибка?
04 мар 2010, 22:09
Mr. Vladimir писал(а):
Ulve
2,52 поддерживает русский язык.
Перевод изменений с последней прошивки чтоли нужен?
04 мар 2010, 22:59
Я думаю просто хотят, чтобы сообщения были обновлены, так как вышла новая прошивка.
05 мар 2010, 00:23
2.51 внедрили ждем вестей с русского сайта Ковон насчет 2.52
05 мар 2010, 11:52
Плеер: cowon s9, v.2.52
Наушники: KOSS The PLUG
а старенькую прошиву уже не качнёшь?? например 2.30.... зачем? оформление нравится, хочется посмотреть вживую так сказать)
02 сен 2010, 19:37
Наушники: Koss port
Добрый день всем, у кого есть живые ссылки на прошивки предыдущих версий до 2.53, был бы рад если бы поделились...заранее спасибо.
03 авг 2011, 14:20
Плеер: Cowon S9, v2.53
Наушники: koss pathfinder
Когда будет новая прошивка=)
05 авг 2011, 00:35
Плеер: sansa clip zip
commandir
халява закончилось :wink:
Fiio E7
05 авг 2011, 00:49
Ну а смысл в новых прошивках для S9(особенно для производителей)? Главное, аппарат путёвый оказался - за 2 года даже аккумулятор практически не сдал, а остальное - фиг с ним :)
07 авг 2011, 21:45
Уважаемый Кассини! А будут вообще выпускаться новые прошивки, или с данной моделью они завязали? У меня он уже 2 года и я до сих пор не нарадуюсь на него и менять не собираюсь. Много было плееров других производителей, но лучше Ковона все-таки нет. Зарядки мне хватает на 3 дня ( по 12 часов в день). Ни разу он мне не доставил каких-то неудобств или неприятностей. Хотелось бы что бы они все-таки развивали удачные модели.
14 ноя 2011, 15:56
