Текущее время: 16 июл 2025, 04:01
Начать новую тему Ответить на тему  [ Сообщений: 64 ]  На страницу Пред.  1, 2, 3, 4, 5  След.
Wallpaper UI Version 3.xx
Наушники: Audio-Technica ES7
Сообщение Re: Wallpaper UI Version 3.xx
кстати, последняя версия 3.34
Update - Patch v3.34
Bug Fix (reported by egrey1): Default values in the User Settings screen for Side B footer were incorrect.
Bug Fix (Reported by RiverRat1) : Default value for Browser's Wallpaper Blender were set to 100/0, should be 0/100. Thats why the behavior was so weird. By default the browser's background is supposed to be completely gray.
Per request (jayteee @ ABI): Change width of the browser scrollbar: Settings -> Browser -> Scrollbar Width. Default width is 25, but can be widened all the way to 40.
Some minor performance improvements in the browser (mostly commonly known AS2 performance optimization techniques). It may improve scrolling speed but who knows ....
Music -> Title Content options renamed from having Track in their names to 'Title' - to make it more consistent.
Per request (ficklampa @ IA): Added Artist-Title option to 'Current Track Display' setting of Main Menu.
Bug Fix (reported by lane32x @ IA): Large swipe area and track advance clips overlapped - shrunk swipe area slightly to fix it.
Bug Fix: Sub-settings failed to return to proper page when using Color chooser.
Bug Fix (reported by jselby): Fixed User Settings title change when accessing special menus (Playlist Manager, App Settings, CIM).
http://www.shapeofcolor.com/cowon/Claw_ ... _v3.34.zip
Добавлено спустя 16 дней 3 часа 17 минут 47 секунд:
Update - Patch v3.35
Update requires x.41 firmware or later
This is just a quick patch to add new EQ settings to Music UI and to Dynamic Playlist configuration setting.
Make sure that UCI Pack 3.33 and patch 3.34 are installed, as usual.
http://www.shapeofcolor.com/cowon/Claw_ ... _v3.35.zip
Wallpapper UI / J3 Theme
noise/electro music fan
29 авг 2009, 22:43
Плеер: Cowon S9 16Gb
А подскажите, пожалуйста, у меня в папке ФлешUI уже есть файл "mainmenu1" (файл темы), и в архиве лежит такой же файл! И что мне делать заменять или переименовать можно что-нибудь? Поскажите...
30 авг 2009, 12:30
версии 3.34 и 3.35 выходили в виде патчей.
т.е. нужно изначально установленный 3.33, потом патч на 3.34 и только потом 3.35. патчи ставятся простой заменой файлов
30 авг 2009, 12:40
Нет... Меня не поняли! Я у становил тему в которй был файл "mainmenu1" и в этой проге тоже есть такой же файл! Если я заменю,то тема исчезнет! Можно что-нибудь сделать что бы и тема сохранилась, и прогой можно было пользоваться???
30 авг 2009, 12:55
нет. эта 'прога' и есть по сути тема (стандартная, хотя видел какие-то переработки других тем), но которую возможно изменять довольно гибко в отличии от дефолтной.
единственное в Wallpaper UI нет настройки видео. пришлось с другой темы взять более гибкую нежели стандартную. тоже вполне неплохо вышло.
каждый файл заменяет определённый экран, поэтому можно хоть из 10 тем сделать винегрет :)
30 авг 2009, 14:57
Спасибо! Теперь понял! Правда в проге все-равно не разобрался! :crazy: Че к чему??? :%)
30 авг 2009, 15:25
в первом посте более менее растолковано.
я сначала тоже не очень понял, теперь понравилось :)
Добавлено спустя 4 часа 40 минут 27 секунд:
Update v3.36 full pack
Per request - disable Side B of Music Footer/Flipbar (Settings -> Music -> Footer Settings -> Disable Side B). If this feature is activated, the Flip button is removed, and one additional slot becomes available to assign for Side A (Music -> Footer Settings -> Functions -> Side A - Slot 6).
Fixed a bug with coloring of browser filenames when color is set to 255/255/255
Fixed a bug which continued to slide album art even if album hasn't changed (based on Stop Slide on Same Album setting).
When pressing Wallpaper button in the Picture UI, the system will now validate if the screen is in Browser mode, and if not, an error message will be displayed.
Per request, added a delete button in the Keypad PIN entry (DEL button).
A new function can be added to an available slot in the Music Footer: Power/Sleep.
A new major (and experimental) feature added - Wallpaper Slideshow (see instructions below).
Misc changes:
User Settings -> System -> Wallpaper -> Wallpaper Timeline renamed to "Enable Timeline".
http://www.shapeofcolor.com/cowon/Claw_ ... _v3.36.zip
Добавлено спустя 6 дней 14 часов 25 минут 56 секунд:
Patch Update - v3.37
Bug Fix [Music uI]: User Settings defined Music's Wallpaper blender as 100/0, but the UI had it as 0/100 ... User Settings had it correct. Only Browser UI should default to 0/100 ...
Select Wallpaper Slideshow change effect: Settings -> System -> Wallpaper -> Slieshow Effect
Effects:
None - wallpapers just change as soon as they're loaded.
Fade In - new wallpaper is faded into view.
Slide Left - New wallpaper slides in from right to left.
Slide animation may appear sluggish depending on your setup. It is unlikely I can improve it much at this point.
Define order of presentation of images in the slideshow (Settings -> System -> Wallpaper -> Image Sequence)
Sequences:
Random - Images selected at random and can repeat from time to time.
Sorted - All selected images are presented in sorted order (if multiple directories are involved, they're sorted as well. This way, if all images are in one directory, named as 01.jpg, 02.jpg, etc - they will play in sequence. When sequence ends it starts from the top.
Shuffle - Entire image list is shuffled into a random order on startup. The slides go through the list, reshuffle, and start again.
The image list is always reloaded, reshuffled, and resorted when most slideshow parameters are modified in the User Settings screen.
When assigning wallpapers in Picture UI, the Screen List will indicate if any of the screens are in Slideshow mode by stating [slide] at the end of the screen name. You can still assign a wallpaper as usual, it just won't be used until Slideshow for this screen is disabled.
New Music Footer functions:
Shuffle. This function bypasses the Boundary popup which has Shuffle as one of its options, and allows toggle of Random/Linear play directly from the Footer.
Main Menu - this is the same button as the top right button.
Browser - this is the same function as the top left button.
http://www.shapeofcolor.com/cowon/Claw_ ... _v3.37.zip
Добавлено спустя 7 дней 20 часов 50 минут 24 секунды:
Update - v3.38 full pack
Settings -> Music -> Hide Overlay Header: Removes the top overlay (with browser / main menu buttons). The removal is only allowed if Main Menu is accessible by one of two other means:
Swipe Function
Footer Function
When the header is removed and album art is set to Large, it is pushed up higher, providing for a better separation between it and the Play Info area.
Change Labels and Label color of any stock icon: Settings -> Menu N -> Icon Settings -> Stock Icons
Enable -> Enable/Disable stock icon (moved from Enable Stock Icons menu).
Label -> Enter/change icon's label.
Label Color -> Enter the color. This overrides global Icon Label Color setting. If you set label color to 0xFFFFFF (255/255/255), global icon label color setting will be used for this icon.
Header Clock Color and Header Volume Color settings in various screens renamed to Info Clock Color and Info Volume Color, respectively. Since that area is called Info Bar, its more appropriate anyway. Plus I need Header stuff for something else.
MSC Playlists settings removed from Browser due to Cowon's implementation of m3u playlists.
Max Static Playlists setting removed from System -> Settings for the same reason.
Ability to manipulate transparency of header/footer background in various screens, or to set it once globally.
System -> Header BG Alpha - set global value for all supported screens' header background (0 to hide).
System -> Footer BG Alpha - set global value for all supported screens' footer background (0 to hide).
Each supported screen has a set of four new settings:
Global Header Alpha -> Set to YES for alpha setting to be read from Global/System value.
Header Alpha -> If not using global value, set to whatever you want here - it overrides global value.
Global Footer Alpha -> Set to YES for alpha settings to be read from Global/System value.
Footer Alpha -> If not using global value, set to whatever you want here.
Currently supported screens:
Menu N
Browser
Radio
Music
Note - by default, headers/footers in all screens except Music UI are set to use global values.
BG Transparency setting under Music -> Footer Settings was removed as redundand - to keep settings consistent across screens
http://www.shapeofcolor.com/cowon/Claw_ ... _v3.38.zip
Patch - v3.38.1
Allow touch functions for play/pause to work when play/pause button removed from the Footer.
When Music header is removed and Play Info is on top, slide the Play Info up instead of album art.
Bug in Stock Icon manager prevented Wallpaper UI's main menu from being copied to anything but Menu 1 and 2. Note that since anything beyond Menu 3 has no settings, you can configure another menu (Menu 3) and rename all SOL/menu3_* files to menuN_* files (where N is another menu number).
Fixed a problem with Theme Tracker working above Menu #4
http://www.shapeofcolor.com/cowon/Claw_ ... 3.38.1.zip
Добавлено спустя 5 дней 6 часов 26 минут 6 секунд:
Patch v3.40
Improved performance of activating a dynamic playlist by adding an Artist cache and a binary search into the algorithm. Speed increase should be more apparent with large playlists. This may not work with some special characters - if it is indeed the case, I will add a switch to have it turned on or off ...
New global playlist setting: Playlist Manager -> Global Settings -> Auto-Clean Playlists. If turned on, when a playlist is being activated and it fails to load a track (i.e. file deleted, etc), it will remove that track from the playlist file and adjust the count. Obviously, not everyone would want it this way (what if you expect to put the file back), so its disabled by default.
When using Paper UCI and selecting Default music option, standard Theme Tracker will take over.
Fixed a bug reported by usb concerning 'Add to Playlist' option missing in Music UI.
Music -> Hide System Bar (page 3): Hides system bar (one with clock and battery) in the Music UI.
Exit User Settings screen quickly -- wherever you are. (m) button is available on the left side of the Title Bar when bailout is possible.
Fixed a bug reported by Lukekeeeee: Settings -> Music -> Seek Bar Color was incorrectly disabled because its dependency was tied to the wrong master switch (Global Footer Alpha).
http://www.shapeofcolor.com/cowon/Claw_ ... _v3.40.zip
Добавлено спустя 20 дней 5 часов 56 минут 47 секунд:
Patch Update - v3.41
Fixed a small bug where changing settings under System menu reinitialized the Theme tracker (not really noticeable but it does incur I/O cost). A similar bug would reload a random wallpaper when it isn't necessary.
Added ability to edit dynamic playlists in a basic way (Playlist Manager -> [select playlist] -> Edit Tracks).
Only two functions are available - remove track and rearrange. The interface is pretty basic but I don't have time to make a fancy one. Note that every time you go into this menu, the playlist is reviewed and repaired if its out of sync, so if you get something like 3 tracks but the count says 8, go into Edit Tracks, and the data should be repaired. The screen layout may need to get changed - right now I can fit only 5 tracks per page (and too lazy to write a 'browser-style' scrolling viewer) - I may increase number or rows by combining artist and album into one row.
Added support for Text in the theme tracker. Also, for developers, overloaded _global.Load_SWF() supports text as an option (i.e. _global.Load_SWF(MODE_TEXT,"someweirdtext.swf").
http://www.shapeofcolor.com/cowon/Claw_ ... _v3.41.zip
Добавлено спустя 2 дня 11 часов 32 минуты 33 секунды:
Update - v3.42 - FULL PACK
Fixed a small bug where Wallpaper Slideshow was reinitialized even when settings for it weren't changed.
Added Wallpaper Vignette (seems like a popular effect these days). The vignette is managed by the launcher and will be in effect for every screen which displays 'Per Screen' wallpapers (Timeline and Slideshow are affected as well). To use:
Enable Vignette functionality: System -> Wallpaper -> Enable Vignette
Enter filename of a vignette overlay: System -> Wallpaper -> Vignette File
The file should be a .png, 272x480, and placed into Flash UI directly. Sample vignettes attached below. The smaller the better of course to speed up startup.
Added Album Art Vignette function. This particular function allows selection of three built-in vignettes and allows typing in a filename of another.
Music -> Album Art -> Vignette Style
None: This is default, and disables the function.
Custom: Enter filename in Music -> Album Art -> Vignette File (272x272, .png, Flash UI dir)
Vignette 1: Sample vignette 1
Vignette 2: Sample vignette 2
Silver Frame: A sample silver frame
I would recommend not using Album Art Frame when using vignettes. I added a sample frame because same function can be used to create interesting frame effects as well
Some notes:
At this time, this function only works when using Large Album Art.
The vignette stays put even when album art is missing (I haven't decided how to handle this yet).
Change look of blank album art image (the gray CD). This deprecates the old Music -> Album Art -> Hide Blank Album Art setting (it should be automatically migrated to the new one when user settings -> Music is opened first time).
Music -> Album Art -> Blank Album Art
None: Disables blank album art (like deprecated option above).
Default: Displays default gray logo.
<Custom>: Allows typing in a new image (272x272 or 200x200, .png, Flash UI dir).
http://www.shapeofcolor.com/cowon/Claw_ ... _v3.42.zip
Добавлено спустя 9 дней 13 часов 11 минут 42 секунды:
Final Preview - 3.43.2b
This is the final beta preview of the new Search function in the browser - it's pretty much where I want it to be, and mostly bug fixes and some search optimization that is left.
Changes since the last version:
Changed Slide in/out animation algorithm.
Added Space Bar.
User Settings support, all located in Settings -> Browser -> Keyboard.
Layout: Set layout to Full keyboard (letters, numbers, space bar), or Minimal (letters only). In minimal layout mode, the keyboard operates in Hotkey mode only.
Start in Mode: Set if you want the keyboard to always start in Hotkey mode, Search mode, or if it needs to track last mode used. This function is unavailable if Layout is set to Minimal.
Opening Effect: None for instant display or Slide Out, for slide animation.
LCD Color: RGB Color of the keyboard LCD screen. To turn off color override, set back to default value (75/75/75).
LCD Text Color: RGB Color of the text displayed in the keyboard.
A Search pattern indicator at the top of the browser will display search text when it is active. When search text is displayed hard volume buttons are used to go to next/prev entry in the browser that matches the pattern.
http://www.shapeofcolor.com/cowon/Claw_ ... .43.2b.zip
21 окт 2009, 21:22
Плеер: Cowon S9, FW 2.51
Update - v3.44 - FULL PACK
Minor internal performance improvements (function caching, etc).
Added Left/Right Balance function to Music Footer (Scales icon).
Playlist Shuffle option now available in the Playlist Manager. Highlight a playlist, press 'Shuffle Tracks', and confirm. The playlist is rewritten in a new hopefully random order. I suggest backing up your playlists (dynplaylist_* files) just in case.
User Settings screen cosmetic changes - replaced the settings tiles with something new instead of borrowing from existing Cowon library. Also removed the (x) button above the confirmation box (it was redundand with the [X] option already present there).
Settings -> Browser -> Remove Extensions: Remove file extensions from the browser. Currently only 3 and 4 character extensions are removed (ie. mpg, flac, wma). This settings is active in Folder browser and in Favorites. Of course, it can reduce performance of browsing if activated.
System -> Wallpaper -> Slideshow Screens renamed to 'Wallpaper Screens'. This group of settings used to allow activating or deactivating Slideshow mode in each screen. It has been extended to also allow a wallpaper to be completely deactivated. So the values for individual screens are:
Per Screen (default)
Slideshow
<None> - this could speed up the system a little if you like the black background.
If a wallpaper is being assigned in Picture UI, a [none] indicator next to a screen name will indicate that the wallpaper is disabled for that screen. You can still assign the wallpaper, but it won't actually be loaded unless the settings are changed.
System -> Wallpaper -> Wallpaper Screens -> Slideshow Screens can be set to:
Individual: Control mode for each screen
All: The slideshow is active for all screens
None: Slideshow is not active
Download full Wallpaper UI Pack 3.44
Download Alternative FPS Launchers (30,40,50,60)
HTC Desire.
Последний раз редактировалось DiveSlip 09 ноя 2009, 11:31, всего редактировалось 1 раз.
Исправление ссылки
09 ноя 2009, 11:31
кстати, разъяснит кто-нить по поводу лаунчера с разным фпс?
13 ноя 2009, 09:43
Всё просто как божий день, чем больше FPS тем шустрее работает интерфейс, но так быстрее садится батарея.
13 ноя 2009, 23:45
странно, у меня и так ничего не тормозит )
13 ноя 2009, 23:58
А я говорил про тормоза?! Я говорил, что он будет работать ещё быстрее, но меньше :)
14 ноя 2009, 01:17
Patch Update - v3.46
"Music -> Play/Total Time" renamed to Music -> Progress Indicators
"Music -> Custom Seek Bar Color" and "Music -> Seek Bar Color" settings moved into Music -> Progress Indicators sub-menu.
"Music -> Progress Indicators -> Seek Bar Knob" - Defines the look of the seek bar knob.
"<Default>" - this uses Cowon's default square knob.
"<Custom>" - this loads a file residing in Flash UI directory called 'music_ui_knob.png'. The file is recommended to be no more than 30x30px, with 18x18px being the optimal size. Make sure not to leave any empty/transparent space around the image - basically left-most edge of the .png should be where the knob image starts (though 1px edge may be ok).
There is a careful alignment that is taking place to allow the image' left-most edge to line up with the left edge of the seek bar. Note that even if the knob is small, 'active' area which triggers seek is larger anyway (40x40).
"Donut" - loads a plain Donut-shaped built-in knob.
"Chrome CD" - loads a Chrome CD built-in knob.
"White Sphere"
"White Triangle"
"Red Speaker"
"Penguin" - BSD/Unix Penguin
"Silver Speaker" - speaker-shaped knob
"Blue Sphere"
"Blue Box"
Most of these are presented simply as examples of what kind of knobs can be used ...
If someone posts a few really cool knobs I may add them to the .swf library for next release.
Knob preview (in same order as listed above):
:beer:
23 ноя 2009, 09:54
у меня не качает
16 дек 2009, 18:46
Татикома
а тут, блджад, все телепаты
HTC Desire.
16 дек 2009, 19:11
