Текущее время: 17 сен 2025, 23:23
Начать новую тему Ответить на тему  [ Сообщений: 342 ]  На страницу 1, 2, 3, 4, 5 ... 23  След.
Rockbox + Patches
 Rockbox + Patches
bootloader от r23511 с рокбоксом по умолчанию тут
Сборка с патчами от Arago
r23546 с config2 тут
    pressing MINUS decreases volume by one,
    pressing PLUS increases volume by one,
    pressing MENU switches between Play and Pause,
    holding MINUS scans backwards,
    holding PLUS scans forwards,
    holding MENU skips forward a track.
r23546 с config5
тут
    When in hold mode, on any list/menu screen or the while playing screen;
    pressing/holding MINUS decreases volume,
    pressing/holding PLUS increases volume,
    holding MINUS skips back a track,
    holding PLUS skips forward a track,
    holding MENU advances to the next folder,
    holding MENU+MINUS scans backwards,
    holding MENU+PLUS scans forwards.
Полный список патчей:
    $ for file in patches/*.patch; do patch -R -p0 --dry-run -i $file -f > /dev/null && echo $file was patched; done
    patches/bootloader.patch was patched
    patches/brickmania.patch was patched
    patches/chopper.patch was patched
    patches/hold_buttons_patch.patch was patched
    patches/invadrox.patch was patched
    patches/jewels.patch was patched
    patches/jpeg.patch was patched
    patches/keyboard.patch was patched
    patches/mazezam.patch was patched
    patches/minesweeper.patch was patched
    patches/mpegplayer.patch was patched
    patches/music_config2.patch was patched (ессно для сборки с config5 - config5)
    patches/pegbox.patch was patched
    patches/png.patch was patched
    patches/rockblox.patch was patched
    patches/time.patch was patched
    patches/viewer.patch was patched
COWON D2 8gb (Черный) + 16Gb
Прошивка: D2+ 2.11 + Rockbox (nightly build :) )
Наушники: Ultimate Ears 3
Последний раз редактировалось PJFry 12 ноя 2009, 15:25, всего редактировалось 6 раз(а).
22 авг 2009, 13:19
Плеер: D2, FW 3.59+Rockbox
Читалка текста. Добавлена прокрутка аппаратными кнопками плюс/минус, включение автопрокрутки кнопкой меню в режиме холд. Брать тут, патч тут.
Плеер видео. Добавлена прокрутка аппаратными кнопками плюс/минус в режиме холд, пауза/play кнопкой меню в режиме холд, скрытие панели управления коротким нажатием выключения. Брать тут, патч тут.
Ядро (rockbox.d2) должно предоставлять функциональность клавиш в режиме холд (спасибо andrewthecoder за код!) (любой конфиг от andrewthecoder или если не хочется управление воспроизведением - ядро только с поддержкой холда можно взять тут, патч тут). Скрытие панели управления и прокрутка будут работать и без этой функциональности.
Последний раз редактировалось Arago 01 сен 2009, 18:05, всего редактировалось 1 раз.
27 авг 2009, 15:06
Плеер: Cowon D2+, FW 2.11
Arago
у него помоему пятый патч был не доделан. там в холде кнопки работали а в нормальном режиме нет. я исправлял. потом прикреплю если найду исправленный.
кстати твои патчи не качаются. 404.
Комментарий к файлу: патч как в первом посте
config5.patch.zip [1.05 Кб]
31 авг 2009, 03:04
Поправил.
Добавлено спустя 3 часа 59 минут 4 секунды:
Тетрис. Добавлено перемещение фигурки вправо/влево аппаратными кнопками плюс/минус, поворот фигурки кнопкой меню, сброс фигурки кнопкой power, перезапуск игры сочетанием кнопок меню и минус, выход из игры сочетанием кнопок меню и power. Брать тут, патч тут.
Арканоид. Добавлено перемещение ракетки вправо/влево аппаратными кнопками плюс/минус, активация действия кнопкой меню. Брать тут, патч тут.
Леталка. Добавлена активация действия кнопкой плюс, активация второго действия (BOTTOMRIGHT) кнопкой минус. Брать тут, патч тут.
Просмотрщик JPEG. Добавлено масштабирование аппаратными кнопками меню/холдменю, прокрутка по горизонтали кнопками плюс/минус, прокрутка по вертикали кнопками холдплюс/холдминус, вызов меню кнопкой power, переключение файлов сочетаниями кнопок меню и плюс/меню и минус. Брать тут, патч тут.
Просмотрщик PNG. Абсолютно то же самое. Брать тут, патч тут.
Ядро (rockbox.d2) должно предоставлять функциональность клавиш в режиме холд (спасибо andrewthecoder за код!) (любой конфиг от andrewthecoder или если не хочется управление воспроизведением - ядро только с поддержкой холда можно взять тут, патч тут). Без этой функциональности не соберётся, а бинарники просто не будут обрабатывать холдкнопки.
Добавлено спустя 5 дней 1 час 2 минуты 41 секунду:
Бутлоадер. Изменён на обратный порядок загрузки Rockbox/Native. Теперь нет нужды терзать холд каждую загрузку (подключать к компу естественно с включенным холдом, иначе будет Rockbox). Брать тут, патч тут, патченный D2N.bin для 3.59 тут, заказывайте другие версии при необходимости. Вот уж не думал что для этого патча мне придётся изучать ARM ассемблер...
07 сен 2009, 00:24
взял,переименовал, закинул в корень и ... И ничего не изменилось. Загрузка по старому. Что делаю не правильно?
07 сен 2009, 23:01
Возможно у вас установлена прошивка для д2+ а поверх нее эту ставить нельзя.
Вот 3.11 для д2+ если что: d2_patched.bin
08 сен 2009, 10:11
Добавлено спустя 1 минуту 36 секунд:
PJFry писал:
Прошивка 3.59, сборка: Rockbox от 22.08.2009 т.е. Ваша, с первого поста , кстати спасибо, работает отлично. У меня ощущение что упускаю какую-то мелочь, вот и не получается. Отпишитесь, у кого работает.[/quote]
08 сен 2009, 18:09
Расширение бин приписывать не надо, думаю у тебя выключен показ расширений, а ты его поэтому не видишь и дописываешь и в итоге имя получается D2N.bin.bin - вот и не выходит. Проверить можешь командой cd /media/D2; ls - она показывает расширения. Кстати, ещё можешь попробовать записать это в плеер через tcctool, если поможет - значит файл подходит и проблема с именем. И вообще, советую проверять любую прошивку через tcctool перед записью, сделать битую гораздо проще чем кажется...
Зашёл к andrewthecoder в патчи - там такой же патч от 08/30/2009. Получается зря я блин ковырялся((
Добавлено спустя 6 минут 57 секунд:
Кстати, кому надо - tcctool, mktccboot.
Добавлено спустя 14 минут 6 секунд:
D2N_3.59_fontpatch_patched.bin. Фонтпатч из темы Cowon D2 OLED III Premium - Rework Suite если интересно, огромный респект Сassini.
08 сен 2009, 20:44
Дело действительно было в показе расширения. Всё работает. Спасибо за помощь!!!
08 сен 2009, 21:33
Это все конечно круто а может ли кто выложить рокбокс включающий все патчи? :)
10 сен 2009, 16:06
Вот так прям всё тебе и сразу... Некоторые патчи тупо несовместимы друг с другом.
Клавиатура. Изменено управление, перемещение выбора влево/вправо кнопками минус/плюс, выбор - меню, стирание - удержание холдменю (в момент отпускания), курсор влево/вправо - удержание холдминус/холдплюс (в момент отпускания), готово - удержание плюс (в момент отпускания), отмена - power. Патч тут.
Радио. Модифицированный config 6 от andrewthecoder, добавлена активация меню пресетов коротким нажатием холдменю, переключение режимов пресет/скан удержанием холдменю (в момент отпускания). Патч тут.
Время. Добавлено перемещение по полям влево/вправо кнопками холдминус/холдплюс. Патч тут.
Эти патчи вкомпилируются в ядро, ядро с патчами config2, radio, time и keyboard тут.
Все патчи обновлены для совместимости с r22670, бинарники пересобраны из r22670, rockbox.zip от r22671 с патчами brickmania, chopper, jpeg, keyboard, mpegplayer, png, radio, rockblox, viewer, time и config2 тут
Последний раз редактировалось Arago 10 сен 2009, 21:25, всего редактировалось 1 раз.
10 сен 2009, 18:35
Arago писал(а):
Все патчи обновлены для совместимости с r22670, ... config2 тут
Вес архива 22 байта. :(
Cowon D2 (2Gb)+Sennheiser CX300
10 сен 2009, 19:59
Перезалил. Странно, но похоже файл был повреждён при переименовании ещё на моей машине...
10 сен 2009, 21:22
Не пугай народ))) 99 процентов на винде.
Arago
Кстати мой любимый патч config5 что то не захотел дружить с последними сборками. :(
А твои не пробовал.
11 сен 2009, 01:06
В последних сборках какойто гений убрал из apps/keymaps/keymap-cowond2.c строчку
{ ACTION_WPS_STOP, BUTTON_POWER|BUTTON_REL, BUTTON_POWER },
потому и не работает патч. Патчи вручную...
11 сен 2009, 06:20
