Текущее время: 16 сен 2025, 16:05
iAUDIO 9 Firmware V1.10
Сообщение iAUDIO 9 Firmware V1.10
Изменения
  • Added mirroring effect of album art on the bottom or selection to display the single line of song title in music mode.
  • Added function of deleting all files in favorite and bookmark list.
  • Added to search from top to bottom in browser by dragging
  • Changed the way of adjusting frequency by dragging in Radio mode.
  • Changed to be scrolled long strings in Settings > Time > Alarm.
  • Edit some menu strings in Settings > Time > Alarm.
  • Improved USB data transmission speed.
  • Fixed the error that abnormal displaying remaining time when it is set to display remaining time.
  • Fixed the error of hanging up when there is a music file that contains faulty album art information.
  • Fixed the error that ID3 tags of some abnormal FLAC file were not displayed.
  • Fixed the error of hanging up while reading tags of abnormal FLAC files.
  • Fixed the error of displaying empty document after wake-up from sleep mode to Text browser.
  • Fixed the error of preview some video clips.
  • Fixed the error that subtitle was not displayed in some movie files or skip to the next file in TV-Out mode.
Добавленные языки
  • Support Hebrew.
  • Changed some menu strings in German.
Скачать
iAUDIO9_1.10.zip [5.72 Мб]
09 дек 2009, 01:18
Плеер: Cowon i9/Z2, Fiio X3
Наушники: DT770 ATH-SJ5 TDS-5M
Сообщение Re: iAUDIO 9 Firmware V1.10
Обновилась прошивка до версии 1.11
28 дек 2009, 16:28
Вот ссылочка :good:
http://www.jetaudio.com/download/iaudio_9_jsfw.html
What's New in Firmware 1.11 (for iAUDIO 9)
Feature Improvements & Bug Fixes
-Added to set M button for sectional repeat in Hold mode.
-Fixed the error that some mp3 files were not playing properly.
-Fixed error after Auto turn-off during recording pause.
Последний раз редактировалось InkvisitoR 04 янв 2010, 12:36, всего редактировалось 1 раз.
29 дек 2009, 17:56
Прошивка лагает..
Аппарат завис и ресет не помогает и комп не видит!
Причем аппарат начинает загружаться, приблизительно на половине стопориться и всё...
после резета всё по новой....
В общем хз что делать, помогите плз... вдруг такие проблемы уже были...
Если сам разберусь (что мало вероятно) отпишусь!
31 дек 2009, 00:10
попробуй ждать. просто ждать. еще можно форматнуть его и заново залить прошивку. сдается мне, он просто стопорится на каком-нибудь глючном файле, когда пытается добавить его в бд. так что проверь еще и теги.
31 дек 2009, 10:56
bill_v2
зрение потерял? комп не видит плеер, теперь остается ждать прог для восстановления... гавнософт выпускает ковон... :(
31 дек 2009, 17:00
bdwind дело было не в прошивке. Прошивка, кстати, нормальная.
bill_v2
+1. Спустя час висяка плеер выключился сам, после чего я его включил и он загрузился. Глюк был вызван альбомом Joe Pass 1974 года во flac'e. Сейчас выясняю что именно ввело в ступор плеер. Скорее всего что-то с тегами, т.к. на компе Audioshell пишет "немогу считать информацию из тега". Проверил как будет с прошивкой 1.10 - еще хуже. Плеером вообще нельзя пользоваться, т.к. после загрузки и выбора языка он виснет и тупит пока батарея не сядет.
P.S.: У друга на Д2 этот альбом не приводит ни к каким глюкам.
03 янв 2010, 14:29
Плеер: Cowon ia9, 1.12
InkvisitoR писал(а):
Прошивка лагает..
У меня было такое же, только что я не делал плеер запустить не удалось, пошел в магазин поменяли без проблем, только так и не выяснелось в чем было дело... :(
Поменять то поменяли, но вот другая проблема. При увеличени громкости она увеличивается только до 32 ед. 33,34 и до 40 громче от этого не становится.... у кого нибудь была такая проблема? что делать....
p. s. Пробовал менять прошивку не помогает....
19 апр 2010, 19:14
А регион и язык какой выбирали?
19 апр 2010, 19:38
язык русский, регион европа
20 апр 2010, 11:36
evzay
Стоит выбрать не Европу, а что-нибудь вроде Other countries.
20 апр 2010, 13:14
думаю вопрос закрыт
20 апр 2010, 19:50
Плеер: Cowon iaudio 9
Прошивка лагает..
А как резет делать???
25 июн 2010, 17:07
На нижнем торце, справа, если положить девайс вниз дисплеем, около USB разъема увидишь дырочку для иголки, это и есть ребут.
25 июн 2010, 17:56
