Текущее время: 18 сен 2025, 05:20
Cowon O2 PMP Firmware v 1.35
Сообщение Cowon O2 PMP Firmware v 1.35
http://www.cowon.com/
корейского к сожалению не знаю :oops:
Добавлено спустя 2 минуты 45 секунд:
http://download.cowon.com/data/C08/O2/O2_V1_35.zip
Добавлено спустя 7 минут 40 секунд:
Movie Player
- WMV9 Simple Profile video encoded in saekbeonjim / Edit flicker
(Some of the content Megastudy saekbeonjim / flashing phenomenon Edited)
- Some headers are not supported at the damaged AVI codec Were your eye fixes
- Improved ability to handle color captions and subtitles abnormal
- Some ASF / WMV file incorrectly identifies the overall duration of symptoms and abnormal behavior modification was
- MPEG4 decoder to improve stability DIVISION
(While playing some DivX video downloads doedeon eye fixes)
- Some large AVI file, it did later phenomenon modify search
- Some sounds mpg regularly in the eye fixes kkeungideon
Music Player
- Album Art Expanded format support: JPG addition to BMP / PNG / GIF / TIFF image format support
- Album art support larger resolutions: JPG Up to 5900 pixel, or other format, 500 pixel
- MP3 playback with album art to improve stability
- Part of MP3 playback with ID3 tags to improve stability
(MP3's ID3 tag header, 0, was filled with the abnormal behavior modification Symptoms)
- Tags: information appears to be broken at the end of the phenomenon is too long Revision
Pictures / Manga Viewer
- BMP pailjung 16Bit RGB565 format support
- If you often download a long file name modification phenomenon doedeon
- Sometimes during bootup your first image was abnormal behavior modification phenomenon
- Some JPEG files that look dark or bright colors or unusual phenomena modify the output doedeon
- Music of the picture / comic viewer with multi-tasking pop music at the end of this unusual behavior to an image doedeon
Symptoms modifying
File Explorer
- Support drag and scroll through
Electronic Dictionary
- Daneojang number of words in the list of supported enlarge an existing 200-500 (electronic dictionaries changed man)
- touch - 00 dictionaries, touch the title displayed at the top when the image is printed on the left eye fixes
Latest files
- SD card from the list of recent files, music, text, simultaneously modifying runtime-down phenomenon doedeon
- During playback of music or movies, the list goes to the user program stored in the list of recent files doedeon way
A list of recent files to the user program at run time to save the file to change the currently playing
Password function
- Set password with the ability to restrict the use of additional equipment
(USB connection to a PC via the device used as a removable disk No Longer Limited)
- [System "Add-ons] After setting the password, use the
- 1-8 digit password can be entered as
- Seoljeonghu password to connect via USB removable disks
.system password.sys . system folder and delete the password file password.sys Cleared
More
- Font changes the font type of bar on the bottom portion of the clock phenomenon it did modify the output Minute
- The system often end at the end of the eye fixes neutdeon
- Sleep settings [setting "power] to change its position on the clock icon at the bottom
* The firmware version of the child should have to downgrade the firmware.
04 сен 2009, 19:08
Плеер: с августа 2009 O2
Сообщение Re: V 1.35
На оффсайте Cowonrussia написано что после её установки откат на старые невозможен!!!
В чем прикол то?
08 сен 2009, 07:50
Удаляешь системную папку и ставишь любую прошу.
09 ноя 2009, 20:34
