Текущее время: 02 сен 2025, 00:14
Cowon O2 PMP Firmware v 1.28
Сообщение Cowon O2 PMP Firmware v 1.28
Изменения (google translate):
Care
  • .system folder, you clear the use of paid content juuihaeju doeohni to stop.
  • The battery is charged enough to upgrade jakeopjeon must connect the power adapter is recommended.
  • I do not turn off during the upgrade.
  • If in case of a PC to backup important files stored on O2, please.
  • After downloading the file in Windows' Safely Remove Hardware 'and then disconnect the USB cable, please.
  • We only provide the program to upgrade the firmware.
Information
  • Files are stored normally available through the disk check, and by regular checking. Can improve the reliability of using the product. (Windows Command window, chkdsk / f drive:)
  • Kowon Media Center - jetAudio using easily convert media formats that are supported by O2 or ripping can be. (AVI, MP4, Musepack, WavPack, TTA, APE, FLAC, etc.)
Скачать
06 апр 2009, 20:48
