Chakra (aka H²O) Final & Aero Music
Что такое H ² O UCI? Это интерфейс с особенностями от Aero Ultimate и производительность Aero VTX. Это сочетание обоих UCI, например, рабочий стол - он похож на один Aero VTX но можно изменить его содержание, как и в Aero Ultimate. Автор: 'NW с форума http://iaudiophile.net
Краткая видео инструкция
Скриншот, так сказать, поскольку вариантов масса показать
Внимание!!!! За вопрос как ставить тему ставлю предупреждение, тихо и быстро. Устанавливать тему надо как описано в FAQ для S9
- Bugfixes - Improved gestures (read note below) - Added menu where you can show/hide lyrics and go to the mainmenu or browser. --- Swipe the sysbar (the bar with time, battery etc information) down to open the menu, and swipe the sysbar up to hide it - Added Track Preview setting to show the track's title only - Tap the tag information area to show filename and other file information (doesn't work in showcase)
How to go to different landscape views:
In standard view, move the album art to the center in order to go to the showcase. Move the album art to the left side to go to Album Art Wallpaper view.
In showcase, move the album art to the left side to go to standard view or move the album art to the right side to go to Album Art Wallpaper view.
In Album Art Wallpaper view, swipe left to go to the showcase or swipe right to go to standard view.
- Bugfixes --- Fixed bug that the lyrics panel isn't shown when you opened a track using Track Preview --- Fixed that the play/pause button flickers under certain conditions in Landscape Mode
Note about the Performance Tweak (Settings > General > Tweak Performance)
If you have problems with the wallpaper staying black after leaving Aero Music, turn this setting off. The tweak removes the wallpaper to improve the performance which causes problems with a few custom launchers.
It works 100%ly with the S9's default Launcher, the J3's default Launcher and Klaus Launcher. About other launchers: I don't know. Just check whether the tweak is causing problems with the wallpaper and turn it off if so.
- Create the folder 'LRC' in the devices root (wher ethe Music, Pictures,... folders are located) - Put the LRC files in the new folder - Rename the files depending on your UCI settings --- Option 'Track's Tags' ----> Rename the files to: 'Title - Artist - Album.lrc' ----> Example: 'A Test - Kizune - Aero Music.lrc' --- Option 'Track's filename' ----> The LRC files must have the same filename as their corresponding track. ----> Example: 'test.flac' -> LRC: 'test.lrc'
The Menu
Press the menu button (button with the arrow pointing down) and the menu opens. But where is AB-repeat, the ability to enable shaking/tilting and the options screen? Just swipe to the left or right side (start the gesture on the menu, not the album art) and you'll see the other menu items.
The QuickAccess Menu
In Aero Music there is a menu similar to Dark Evolution's QuickAccess menu, but you open it in another way here. Just press and hold the menu button to open the QuickAccess menu. Note: S9 users won't see the button to change the speaker mode (on, off, auto).
The Playlist Manager
The Playlist Manager can be found in the third page of the menu. When you tap the button, the menu closes and the playlist viewer opens. There are no playlists yet of course. Tap the X button to close the viewer, or tap the right button to open the Playlist Manager. Here you can add and remove playlists.
When you have added a playlist, you have to fill it first. Open it in the manager and then tap 'Fill Playlist'.
You can remove or rearrange track by going into the playlist and tapping 'Tracks'. Then you'll see the playlist entries. The buttons to rearrange/remove tracks are invisible. Tap a track entry on the first third of the screen to move it up, tap it in the middle of the screen to move it down, or tap it on the third third of the screen to remove it. Don't worry, while you press a button there is a popup shown which shows which action you're about to perform.
Что такое H ² O UCI? Это интерфейс с особенностями от Aero Ultimate и производительность Aero VTX. Это сочетание обоих UCI, например, рабочий стол - он похож на один Aero VTX но можно изменить его содержание, как и в Aero Ultimate. Автор: 'NW с форума [url]http://iaudiophile.net[/url]
Краткая видео инструкция [youtube]OrLx13sKZvY[/youtube] [youtube]1yqPeyLGi2k[/youtube] [spoiler=Скриншот, так сказать, поскольку вариантов масса][img]http://fc01.deviantart.net/fs71/f/2010/190/f/c/H2O_UCI_Concept_07_10_2010_by_5nw.jpg[/img][/spoiler]
[size=150][color=#FF0000]Внимание!!!! За вопрос как ставить тему ставлю предупреждение, тихо и быстро. Устанавливать тему надо как описано в FAQ для [url=http://cowonworld.ru/forum/viewtopic.php?f=13&t=208]S9[/url] [/color] [/size]
[center][color=#0000FF][size=150][url=http://iaudiophile.net/forums/showthread.php?t=38293]Плагины и виджиты[/url][/size][/color][/center]
Aero Music v1.0 Final Released
Changes:
The Menu
You can remove or rearrange track by going into the playlist and tapping 'Tracks'. Then you'll see the playlist entries. The buttons to rearrange/remove tracks are invisible. Tap a track entry on the first third of the screen to move it up, tap it in the middle of the screen to move it down, or tap it on the third third of the screen to remove it. Don't worry, while you press a button there is a popup shown which shows which action you're about to perform.[/spoiler]
09 окт 2010, 01:55
Aloteot
Re: Chakra (aka H²O) Final & Aero Music Beta
что-то я туплю %( а где в новой чакре запускать сторонние приложения? а то двадцать минут возни и все еще чувствую себя дегенератом...
Aloteot Там ини файл есть. В него нужно пути прописать. С компа конечно-же. В стандартном наборе в нем уже прописан путь до календаря.
[b]Aloteot[/b] Там ини файл есть. В него нужно пути прописать. С компа конечно-же. В стандартном наборе в нем уже прописан путь до календаря.
14 янв 2011, 14:04
Serj
Зарегистрирован: 25 июн 2009, 21:21 Сообщения: 21 Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon J3 32Gb
Стал счастливым обладателем J3. Поставил эту тему оформления. Или это я так поставил, или это баги. 1. Когда создаем папку из виджетов она(папка) пропадает с экрана и виджеты больше не видны, их даже перетащить из меню нельзя. 2. Если на одном рабочем столе два больших виджета и перенести к нему еще один маленький(из стандартных ярлыков) то они будут периодически исчезать, если по переключаться между рабочими столами, то они снова появляются. 3. Также нельзя редактировать (я пока не нашёл или этого нет) положение "ярлыков", т.е. чтобы переместить значки нужно сначала добавить новый какой нибудь и только потом можно редактировать другие.
18 янв 2011, 02:38
Alexander-SPb
Serj То что здесь выложено уже старое. Нужно отсюда качать.
[b]Serj[/b] То что здесь выложено уже старое. Нужно [url=http://iaudiophile.net/forums/showthread.php?t=38293]отсюда[/url] качать.
18 янв 2011, 03:21
Serj
Alexander-SPb Там и брал. Она сначала не ставилась, но потом я скинул все файлы(из корня архива и папки чакра) в папку флеш уи и она заработала.
[b]Alexander-SPb[/b] Там и брал. Она сначала не ставилась, но потом я скинул все файлы(из корня архива и папки чакра) в папку флеш уи и она заработала.
вопрос, если соблюдая иерархию закинуть тему на флешку, она заработает?
меж делом на iaudiophile.net обновились UCI:
Chakra v1.03
What's New?
- Added resume feature ---> If enabled, this feature opens the last UI you were in before shutting down ---> MODE_ETC UIs are excluded due to impossibility of obtaining the file which was loaded. This affects: Calculator, Hunter, Stopwatch, Comix and other UIs ---> This feature even detects that you change the UI when you aren't using Chakra
Aero Music v1.0 Beta 8
Changes:
- Bugfixes - Enabled gestures in Lyric Viewer (except when TXT lyrics are shown) - Added possibility to give user EQs custom names in EQ editor (the second infobar still shows 'User X' as current EQ) - Added option to disable upscaling ---> Since I have to load the full album art to determine whether it's smaller than 272x272, album art larger than 272x272 is pixelated
Note:
Disable the g-sensor or set it to tilt to prevent problems. The horizontal mode is about to be added and causes in the current version only a black screen. It goes back to normal when you go to portrait mode, but the UI will be crazy then.
меж делом на [b]iaudiophile.net[/b] обновились UCI:
[b]Chakra v1.03[/b]
What's New?
[b]Aero Music v1.0 Beta 8[/b]
Changes:
Note:
Спасибо. Завтра утром поправлю шапку. Сегодня я работаю.
18 янв 2011, 13:25
0n3g1n
Зарегистрирован: 18 ноя 2010, 18:41 Сообщения: 210 Откуда: Киев Благодарил(а): раз. Поблагодарили: раз. Плеер: iPod Nano 1g, 1.3.1 Наушники: Sony MDR-EX10LP
Поздравляю
На любом ярлыке зажмите пальцем, через пару секунд будет доступно передвижение и редактирование.
___ п.1 не понял, п.2 не встречал
[quote="Serj"]Стал счастливым обладателем J3.[/quote] :good: Поздравляю :beer: [quote="Serj"]нужно сначала добавить новый какой нибудь и только потом можно редактировать другие.[/quote] На любом ярлыке зажмите пальцем, через пару секунд будет доступно передвижение и редактирование.
___ п.1 не понял, п.2 не встречал :crazy:
_________________ был: J3 16GB v.2.25 + 8GB ::: Chakra v1.02 + Piano [Music] + Squarescape [Video] + Klaus Browser + Text Viewer / Klaus Edition есть: iPhone 5 + iPad Air
18 янв 2011, 22:40
Vitalik
Зарегистрирован: 23 янв 2011, 15:02 Сообщения: 1 Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon j3 fw 2.03 Наушники: Sennheiser PX 100-II
А у меня после установки Chacra Full первый раз он загрузился нормально, появились иконки, при перелистывании рабочих столов долго думал, потом просто завис намертво, после перезагрузки не захотел даже иконки грузить, снова завис. Не могу понять почему...Может ли причиной быть прошивка 2.03?
23 янв 2011, 17:49
Aloteot
Vitalik Очень может, и вообще следует обновиться до 2.23 (или выше ^^)
[b]Vitalik[/b] Очень может, и вообще следует обновиться до 2.23 (или выше ^^)
You can... ... navigate through files and folders in the usual manner ... open files ... use physical buttons to control music
You cannot... ... add faves or delete files ... use gestures (except for scrolling) ... view bookmarks or faves
The browser always returns to the mainmenu, no matter whether you open a music file or a picture.
Наконец то Функционал явно до Клауса не дотягивает но для полного набора подойдет
Добавлено спустя 3 часа 7 минут 19 секунд:
Постараюсь обновлять пост по мере появления Обновлений
[color=green][size=80]Добавлено спустя 16 часов 45 минут 24 секунды:[/size][/color]
[b]Aero Music v1.01 Released[/b]
[b]Changes:[/b]
[b]Note about the Performance Tweak[/b] (Settings > General > Tweak Performance)
Зарегистрирован: 03 фев 2011, 23:28 Сообщения: 5 Благодарил(а): раз. Поблагодарили: раз. Плеер: Cowon J3 2.23
Ни как не могу понять, почему темы не ставятся.. Закинул в папку SYSTEM>Flash UI, но после перезапуска - Реакции 0, все по прежнему.. Атрибуты в файлах не прописаны, что может быть причиной? Aero - ставится. Chakra нет...
Ни как не могу понять, почему темы не ставятся.. Закинул в папку [b]SYSTEM>Flash UI[/b], но после перезапуска - Реакции 0, все по прежнему.. Атрибуты в файлах не прописаны, что может быть причиной? Aero - ставится. Chakra нет...
03 фев 2011, 23:38
Sebostian Название файлов правильно выставили? Смотрите внимательно. Я сам сижу на чакре.
[b]Sebostian[/b] Название файлов правильно выставили? Смотрите внимательно. Я сам сижу на чакре.
04 фев 2011, 00:02
Sebostian
