Текущее время: 31 авг 2025, 11:12
COWON D3 PRO firmware version 5.04 & 6.04
Ребзы!
Вышло вот такое:
Information
COWON D3 Pro firmware version 6.04 is for upgrading version of x.53/x.54/x.55.
If the version of the firmware installed on your device is lower than x.53 version,
please install the x.53 version first before upgrading to version 6.04.
Firmware version of your device can be checked at Settings > About D3 > Firmware version.
Warning/Caution
Back up any important data before firmware upgrade.
Please pull out the MicroSD card that was inserted in D3 before firmware upgrade.
Please make sure the AC adapter is connected during firmware upgrade.
Do not turn off the device before firmware upgrade is completed.
Power shortage might cause damage on the device, and the damage will not be covered by warranty.
Adjusted D3 Pro GUI and JetEffect 5
Software and system optimization
NOTE 1: JetEffect is not activated during fast forwarding.
NOTE 2: D3 Pro firmware is focused on multimedia functions. Internet access will be limited under D3 Pro
firmware. To use the Internet, please download and install Vx.55 firmware.
NOTE 3: For stable operation, FAT32 format is recommended. NTFS format is for playing big size media files
that are over 4GB. Please be sure to use ‘Safely Remove Hardware’ to protect file system before
disconnecting the cable from a PC after transferring data when using NTFS. For playing normal
media files, FAT32 is recommended.
Линк на в. 5.04 - http://download.cowon.com/data/C08/D3/5_04/update.zip
Линк на в. 6.04 - http://dn2.cowon.com/data/C08/D3/6_04/update.zip
Обращаю внимание, что рекомендуют обновляться с версии x.53
Линки на x.53:
2.53 - http://dn2.cowon.com/data/C08/D3/x_53/D3_Upgrade_installer.V2.53(EU).zip
3.53 - http://dn2.cowon.com/data/C08/D3/x_53/D3_Upgrade_installer.V3.53(US).zip
4.53 - http://dn2.cowon.com/data/C08/D3/x_53/D3_Upgrade_installer.V4.53(GL).zip
07 дек 2014, 15:31
Плеер: Cowon X7, FW 2.08
Наушники: Sennheiser HD 380 PRO
Сообщение Re: COWON D3 PRO firmware version 5.04 & 6.04
Недавно ставил эту прошивку.
В принципе не плохо, быстрее работает, в звуке, как ни странно, изменений не обнаружил))
Внешне напоминает ковоновские фирменные прошивки.
Отрубается вай-фай, да и все андроидовские фишки. Не критично, наш плеер их итак фактически не тянет)
И, кстати, рекомендуют обновляться если на устройстве установлена прошивка не ниже х.53
19 дек 2014, 12:05
Плеер: no
Наушники: sony mdr nx1
Извеняйте что пишу под этим ником, но регистрация, увы, закрыта... Подобрал логин\пароль методом тыка))
Опишите плиззз прошивки 5.04 и 6.04
Никакой инфы не смог откопать, и на форуме никто не отписался... Насколько аппарат стал дольше держать батарейку и тд...
20 апр 2015, 22:17
Плеер: no
Установил версию 6.05.
Не работает установка приложений. Как быть, кто-нидь знает?
15 сен 2015, 11:33
