Текущее время: 17 сен 2025, 00:55
ALL Firmware Upgrade COWON Z2
Какой прошивкой прошит Z2?
V1.33 41%  41%  [ 7 ]
V1.32 6%  6%  [ 1 ]
V4.31 41%  41%  [ 7 ]
V3.31 0%  0%  [ 0 ]
V2.31 0%  0%  [ 0 ]
V1.31 0%  0%  [ 0 ]
V1.30 0%  0%  [ 0 ]
V1.28 0%  0%  [ 0 ]
V1.25 12%  12%  [ 2 ]
V1.15 0%  0%  [ 0 ]
Всего голосов : 17
Плеер: COWON Z2 Plenue 32Gb
Наушники: sennheiser hd 418
Firmware Upgrade V1.33 COWON Z2 показать
материал взят у kotbasilio http://cowonworld.ru/forum/viewtopic.php?f=71&t=5797
http://download.cowon.com/data/C08/Z2/1_33/update.zip
гугл транслейт
System
Screen Capture functionality chugaju 1)
Each control in the status bar to display the settings screen, press and hold button
FAT32 formatting features chugaju 2)
Music Player
Bluetooth screen off during playback to stop when crossing the state error correction in the next song
Cowon Hangul Input Method
A Bluetooth keyboard with Shift + Space / 0 mode conversion added
Add App
MediaShare chugaju 3)
Facebook, Twitter, Me2Day, Cyworld SNS Manager is managing at the same time, additional
App Update
Ole Market
Other bug fixes
Note 1) at the bottom of the previous button (Back) 'while holding down the screen by pressing the power button once kaepchyeoham
Capture files Recordings \ Screenshot \ folder is stored in
Note 2) built-in memory with the FAT32 file system pomaetham
Set the built-in memory format ▶ ▶ ▶ FAT32 storage
Week 3) Z2 or music stored on other DLNA enabled devices, video, photos, and media content
By sharing with each other via Wi-Fi jaesaengham
Bit rate is high or where there are differences between products compatible with standard playback and control may not be smooth
Firmware Upgrade V1.32 COWON Z2 BETA показать
http://download.cowon.com/data/C08/Z2/1_32_beta/update.zip
гугл транслейт
System
Music Player
Add App
Add MediaShare Note 3)
App Update
Ole Market
Other bug fixes
COWON Z2 Firmware Vx.31 показать
EU Version (v2.31)Firmware Version 2.xx http://dn2.cowon.com/data/C08/Z2/x_31/2_31/update.zip
North American Version (v3.31)Firmware Version 3.xx http://dn2.cowon.com/data/C08/Z2/x_31/3_31/update.zip
Non-EU Version (v4.31)Firmware Version 4.xx http://dn2.cowon.com/data/C08/Z2/x_31/4_31/update.zip
гугл транслейт
Warning/Caution
Back up any important data before the firmware upgrade.
Please remove MicroSD card before the firmware upgrade.
Please make sure the AC adapter is connected while upgrading firmware.
Do not turn the player off before the firmware update has been completed.
It may damage the product, and will be void any warranty.
Systems
Improved JetEffect 5.
Improved sound quality while using with external music player.
Added playback control in Screen Lock.
Added “Display screen lock” in settings. 1)
Added “Display hold” in settings. 2)
Added “Airplane mode” in settings. 3)
Fixed the error of displaying “insignificant memory” while downloading Applications.
Music Player
Improved Settings of JetEffect User EQ. - Directly adjusting, Drag Adjusting, Step Adjusting.
Fixed the error that files from other folders are played while set boundary as folder.
Applied to resume the location of playback in folder boundary after rebooting system.
Stabilized displaying LDB lyrics feature.
Video Player
fixed to display subtitles correctly even the subtitle file contains an error in time setting.
Radio
Fixed the channel scanning error while changing location.
Comix
Fixed the error with ZIP file list.
Added App
Added File Manager (Copy, Delete, Send and Run etc…)
Fixed other bugs
1)Display playback control without unlock screen.
Settings > Location & Security > Set up screen lock > Display screen lock
2)Press the power button to hold display.
Settings > Display > Display hold
3)Disable all wireless connection.
Settings > Wireless & networks > Airplane mode.
Firmware Upgrade V1.31 COWON Z2 показать
материал взят у kotbasilio http://cowonworld.ru/forum/viewtopic.php?f=71&t=5647
http://download.cowon.com/data/C08/Z2/1_31/update.zip
spoiler=гугл транслейт
System
Improve JetEffect 5
Improve sound quality when using an external music player
Lock screen (Screen Lock) added to the music playback controls
"Display Screen Lock 'setting chugaju 1)
'Display Hold' setting chugaju 2)
'Airplane mode' chugaju 3)
Market for downloading 'lack of capacity "phenomenon does not occur, so that modifications
Music Player
JetEffect User EQ setting screen enhancements - Direct adjustment, dragging the adjustment, step adjustment
File folder to another folder during repeat playback error correction
Folder, reboot while playing the last to remember the playback position applied
LDB display lyrics stabilization
Video player
Subtitles on time even if there are errors in the top section to display the subtitle fixes
Radio
Area scan error correction when changing channels
Cowon T Message
Change the order of time alignment
'Already, but sent a message "Error Correction
Comic Viewer
ZIP file, a list of error correction
Add App
Add a file manager (copy, delete, transfer, execution, etc.)
App Update
ucloud, Ole Market
Other bug fixes
Note 1) without locking the screen immediately displays the screen
Set the location and security ▶ ▶ ▶ lock screen lock screen display settings
2) Displaying the screen by pressing the power button once the screen holdeuham
▶ ▶ On-screen display settings hold
3) Disable all wireless connections
▶ ▶ airplane mode wireless and network settings
Firmware Upgrade V1.30 COWON Z2 показать
материал взят у DiveSlip http://cowonworld.ru/forum/viewtopic.php?f=71&t=5596
http://download.cowon.com/data/C08/Z2/1_30_beta/update.zip
гугл транслейт
Система•Улучшение JetEffect 5
•Улучшение качества звука при использовании внешнего музыкального плеера
•Блокировка экрана (Screen Lock) добавлены элементы управления воспроизведением музыки
•"Display Screen Lock" установка дополнительных неделю)
•"Показать Hold 'установка дополнительных примечание 2)
•Рынок отсутствие загрузки "способностей" явление не происходит, так что изменения
Музыкальный плеер•JetEffect User EQ настройки экрана усовершенствований - Прямое регулирование, волоча по высоте, регулировка шага
•Файл папки в другую папку во время повторного воспроизведения коррекции ошибок
•Папка, перезагрузка во время игры последнего вспомнить позицию воспроизведения применяется
•LDB дисплей текст стабилизации
Видеоплеер•Субтитры на время, даже если есть ошибки в верхней части для отображения субтитров исправления
Радио•Площадь сканирования коррекции ошибок при смене каналов
Сообщение Cowon T•Изменение порядка времени выравнивание
•"Уже, но послал сообщение" Error Correction
Comic просмотра•ZIP файл, список коррекции ошибок
Добавить приложение•Добавить файловый менеджер (копирование, удаление, передача, выполнение, и т.д.)
App Update•ucloud Оле рынка
Другие исправления
Firmware Upgrade V1.28 COWON Z2 Beta показать
http://download.cowon.com/data/C08/Z2/1_28_beta/update.zip
гугл транслейт
Firmware Upgrade V1.28 COWON Z2 is a beta.
Revised history can be found at the link below to download data to the caveats discussed with
After confirmation to proceed with the upgrade, please give me.
In the future based on your opinion in order to provide more satisfactory products best
Promise to do.
COWON all who love you thank you again.
Important data before the firmware upgrade is in progress, please back it up.
Also be included in Z2 after removing the MicroSD card, please proceed.
During a firmware upgrade, please help keep the power adapter connection.
Never before the firmware upgrade is complete, Do not power off.
If the power is turned off in the middle of, damage to equipment can come free A / S will not be provided.
When using a beta firmware may cause instability symptoms.
Instability at the onset of symptoms to the most recent official firmware update, please use.
System
Improve JetEffect 5
"Display Screen Lock 'setting an additional week)
'Display Hold' setting additional Note 2)
Music Player
Video player
Radio
Cowon T Message
Comic Viewer
Add App
App Update
ucloud, Ole Market
Other bug fixes
файловый менеджер) ничего вроде такой
и в блоке выплывающая фигулинка плеера)
Firmware Upgrade V1.25 COWON Z2 показать
материал взят у carbon http://cowonworld.ru/forum/viewtopic.php?f=71&t=5570
http://download.cowon.com/data/C08/Z2/1_25/update.zip
гугл транслейт
Using a network server, add the automatic time setting function
Modify USB charging function
Music albums and photo scan the thumbnail images to improve 1)
Kowonhangeulipryeokgi (keyboard) when you open a closed Hangul / English / symbol remains
Music Player
If the file in the list of songs that caused a lot of error correction
When playing a file from the list of folders to another folder, the file is playing, error correction
Add View button gasachang
Video player
I played before, keep the setting of the subtitle languages
Calculators
Change the numeric keypad array
App Update
Kakaohtok
Other bug fixes
Note 1) after updating the firmware update media database are encouraged.
Privacy Settings ▶ ▶ media database updates
Последний раз редактировалось maximmax 25 май 2012, 23:06, всего редактировалось 9 раз(а).
22 мар 2012, 21:27
Сообщение Re: Прошивка 1.28 Корейская.
Уже 1.30 появилась.
23 мар 2012, 12:36
они ими там плюют шоле)?
23 май 2012, 08:46
Сообщение Re: ALL Firmware Upgrade COWON Z2
Людии..если не можете найти прошивку- ищите тут. всегда обновляю. и не мучайтесь-шейтесь на 1.33 ну или 4.31- будет меньше неприятных моментов перезагрузов итд.
ну и голосуйте )
25 май 2012, 23:10
Плеер: cowon z2
Наушники: sennheiser IE4
Вчера обновился v 4.35
16 авг 2012, 10:21
Плеер: Cowon Z2
Наушники: Bose QuietComfort 15
Говорят, что работает не очень прошивка. Правда так что ли?
23 фев 2013, 23:44
