Текущее время: 17 сен 2025, 00:55
COWON Z2 Firmware Vx.31
Плеер: COWON Z2 Plenue 32Gb
Наушники: sennheiser hd 418
Сообщение COWON Z2 Firmware Vx.31
http://cowonglobal.com/ выложила прошивочки
текст изменений итд показать
Warning/Caution
Back up any important data before the firmware upgrade.
Please remove MicroSD card before the firmware upgrade.
Please make sure the AC adapter is connected while upgrading firmware.
Do not turn the player off before the firmware update has been completed.
It may damage the product, and will be void any warranty.
Systems
Improved JetEffect 5.
Improved sound quality while using with external music player.
Added playback control in Screen Lock.
Added “Display screen lock” in settings. 1)
Added “Display hold” in settings. 2)
Added “Airplane mode” in settings. 3)
Fixed the error of displaying “insignificant memory” while downloading Applications.
Music Player
Improved Settings of JetEffect User EQ. - Directly adjusting, Drag Adjusting, Step Adjusting.
Fixed the error that files from other folders are played while set boundary as folder.
Applied to resume the location of playback in folder boundary after rebooting system.
Stabilized displaying LDB lyrics feature.
Video Player
fixed to display subtitles correctly even the subtitle file contains an error in time setting.
Radio
Fixed the channel scanning error while changing location.
Comix
Fixed the error with ZIP file list.
Added App
Added File Manager (Copy, Delete, Send and Run etc…)
Fixed other bugs
1)Display playback control without unlock screen.
Settings > Location & Security > Set up screen lock > Display screen lock
2)Press the power button to hold display.
Settings > Display > Display hold
3)Disable all wireless connection.
Settings > Wireless & networks > Airplane mode.
EU Version (v2.31)Firmware Version 2.xx http://dn2.cowon.com/data/C08/Z2/x_31/2_31/update.zip
North American Version (v3.31)Firmware Version 3.xx http://dn2.cowon.com/data/C08/Z2/x_31/3_31/update.zip
Non-EU Version (v4.31)Firmware Version 4.xx http://dn2.cowon.com/data/C08/Z2/x_31/4_31/update.zip
Добавлено спустя 6 часов 35 минут 50 секунд:
так вот там красным по белому написано * Please check version of firmware on Settings > About Z2 > Firmware version.
так если у меня сперва 1.хх была потом другие 1.хх сейчас 1.31, а если 4.31 накатить то что))) никаких изменений? или корейские приложения делитнутся?да и вообще встанет ли она?
10 май 2012, 18:20
Плеер: Processing...
Сообщение Re: COWON Z2 Firmware Vx.31
maximmax писал(а):
так вот там красным по белому написано * Please check version of firmware on Settings > About Z2 > Firmware version.так если у меня сперва 1.хх была потом другие 1.хх сейчас 1.31, а если 4.31 накатить то что))) никаких изменений? или корейские приложения делитнутся?да и вообще встанет ли она?
Тоже интересует. Надо сходить в ветку D3 :) Думаю, отличие в корейских приложениях, ну и ещё паре мелочей. Накатить тоже должно быть можно, а пишут чтобы пользователь перепрошившись не офигел от количества корейских ништяков.
Последний раз редактировалось Kesha2000 11 май 2012, 00:34, всего редактировалось 1 раз.
10 май 2012, 20:04
Плеер: z2
Наушники: Sennheiser CX 200
прошивка встала без проблем, корейские ништяки исчезли
11 май 2012, 00:29
Найс.
11 май 2012, 00:35
pohabych
написал бы поширше. какая была и какую ставил 2.хх 3.хх или 4.хх?
было бы неплохо если бы они клаву запилили туда русскую за место корейских
11 май 2012, 06:04
Плеер: z2
maximmax была 4.31 А, поставил 1.31, глюки с карточкой не исчезли, поставил 4.хх, оказалось, что эта родная прошивка, с которой покупал плеер.
Что ты подразумеваешь под клавой? Есть там русские буквы. И в 1.31 из соседней ветки была тоже...
11 май 2012, 11:44
pohabych
да есть) но я думал они Cowon Korean Inputmethod с русским сделают. мне там англ раскладка понра..а рус нету.. так я накатил Smart keybord.
11 май 2012, 11:57
Плеер: Cowon Z2, FW 2.31
Коллеги, поставил EU версию, уровень громкости стал заметно ниже...Перешиваться на корейскую?
И создал Бог Женщину...существо получилось злобное,но забавное,и приятное...на ОЩУПЬ.
16 май 2012, 15:46
Everio
Non-EU Version (v4.31)Firmware Version 4.xx попробуй!
16 май 2012, 16:09
maximmax писал(а):
Everio
Так и сделал. Зэр Гут! :)
17 май 2012, 11:15
